BWM feature rule to bypass interface Egress rate limit
How this would work and be useful if you don't have a L3 switch
On a FLEX 200 (non H) you limit on the interface LAN1 egress to 204800kbps but you have LAN2 and you want LAN1 to receive at full speed from LAN2 thats where this rule comes in to bypass the interface Egress rate limit by a rule LAN2 to LAN1.
Now you might think why not just not set a interface Egress rate limit and use BWM rules? Does not work the more rules you have like
rule 1 from LAN1 to WAN max inbound to 204800kbps
That on its own would work but if you did
rule 1 from LAN1 to WAN TCP_any Guaranteed inbound 102400kbps max inbound to 204800kbps
rule 2 from LAN1 to WAN UDP_any Guaranteed inbound 102400kbps max inbound to 204800kbps
Now you have a problem you want max speed at any given time but the max of 200Mb but with the above its 400Mb if both protocols are used where as with interface Egress rate limit at 204800kbps the two protocols stay under 200Mb and BWM does what it can to deliver so if TCP is only used 200Mb if UDP is only use 200Mb if both 200Mb
Hi @PeterUK
So, you need:
- From LAN 1 to any egress to 204800kbps (inbound 204800kbps).
- From LAN 1 to LAN 2 without the limit above.
For this purpose, if you use:
- rule 1 from LAN1 to WAN max inbound to 204800kbps.
- rule 1 from LAN1 to WAN TCP_any Guaranteed inbound 102400kbps max inbound to 204800kbps
- rule 2 from LAN1 to WAN UDP_any Guaranteed inbound 102400kbps max inbound to 204800kbps
With these three rules (what's the priority of these rule?), the maximum speed will not reach 400M but share with in 200M?
Zyxel Melen0 -
So Melen
Its more from LAN2 to LAN1 where LAN1 is receiving
That not how BWM rules(but I with test to be sure) works priority is 7 (on all rules as the way priority works is unforgiven unless used correctly with the current way it works) if the rules follow in order the 1st rule will only happen for all protocols rule 2 and 3 will not happen?
Edit after testing here yes rule 1 is used the other rules are not used
Then the other problem is what if you have traffic from WAN to LAN1 which will push over the 200Mb if both sides LAN1 to WAN and WAN to LAN1 happen at the same time.
- 439 Beta Program
- 2.8K Nebula
- 193 Nebula Ideas
- 6.2K Security
- 473 USG FLEX H Series
- 310 Security Ideas
- 82 Switch Ideas
- 282 Service & License
- 443 News and Release
- 4.3K FAQ
- 93 Security Highlight
