Blocking devices that use Randomized MAC Addresses to connect to SSID
Linda
Linda Posts: 11 image  Freshman Member
I will block devices that are connected to an SSID that they are not supposed to, but because they have randomization turned on, they can get a fresh MAC address and reconnect. Devices are BYOD so I can't force people to turn it off in their settings.
1 votes
Active · Last Updated
    Their is nothing you can do about the device that Randomized MAC it can not be known that it is random MAC only that its a new MAC.
    One way to deal with this is a MAC filter of allowed MAC's but if thats not a option nothing anyone can do about it.
  • Linda
    I believe randomized MAC addresses have 2, 6, A or E as their second digit. So it'd be nice if there is a setting to deny connection from devices with MAC addresses starting with *2, *6, *A, or *E.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,602 image  Zyxel Employee
    Hi @Linda,
    We will evaluate this idea. However, it is recommended to use:
    1. 802.1x for authentication. (If your model supports 802.1x)
    2. MAC authentication to allow know MAC address. (Require to learn the MAC addresses of accepted devices.)
    Zyxel Melen
