USG Flex 200 Connectivity Check
Hi @MMRHCM
Could you share your purpose? Do you want to use commands to check connectivity or configure connectivity check?
Zyxel Melen0 -
I know how to configure a connectivity check in the GUI. I'd really like to perform this using snmp.
Discovered "show connectivity-check status" but would prefer something more efficient than scripting an ssh session to check this on each wan interface every 5 minutes across our ~45 firewalls.
Hi @MMRHCM
Connectivity check uses ping to check the connectivity. If you want to perform connectivity check, you can just use a ping with a specific interface to check.
Here is the commend:
ping {ipv4_addr | hostname} [sourceipv4] [size <0..65507>] [forever |count <1..4096>] [interfaceinterface_name] [extension filterextension]
Additionally, SNMP requires the device to support this type of MIB to process pings. Since it is not included in our MIB file, I'm clarifying if the USG FLEX series endorses this kind of MIB. I will update you once I get further information.
Zyxel Melen0 -
Hi @MMRHCM
In addition, our connectivity check can set:
- Check period. (How long the device do a ping check) (5~600 seconds.)
- Check Timeout. (How long the device wait for the response) (1~10 Seconds.
- Check Fail Tolerance. (How many time the
You can change these options to enable frequent connectivity checks.
Zyxel Melen0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
