problem
inforossipb
inforossipb Posts: 2 image  Freshman Member
i HAVE BUY wbe660 ap AND NWAX110 REPEATER AND I WANT CONNECT PC ON NETWORK CARD NWAX110, BUT CANT WORK
  • Zyxel_Tina
    Zyxel_Tina Posts: 642 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @inforossipb,
    The NWA110AX does not support the wireless bridge function when operating as a mesh repeater, meaning its LAN port cannot provide wired network access to a connected PC in this mode. You may refer to this article to check which Zyxel AP models do not support wireless bridge mode.
    To resolve this, consider these options:
    1. Use the NWA110AX as a standard Access Point: Connect the NWA110AX via Ethernet to your main network. Its LAN ports will then function normally for wired client connections.
    2. Replace the NWA110AX : If you need a wireless repeater with an active LAN port for wired clients, you'll need a model that supports the wireless bridge function. Supported Zyxel models include WBE660S, NWA55AXE, WAX610D, WAX650S, and NWA130BE.
    3. Connect the PC wirelessly: Your PC can connect to the NWA110AX wirelessly.
    Zyxel Tina
