[USG Flex H] - Policy Control - Wrong Source/Destination Group
Maverick87
Maverick87 Posts: 538
Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate
image  Guru Member
edited October 2025 in USG FLEX H Series
Hello everyone,
I have created an group object that contains other groups.
When I configure it as Source/Destination of a Policy Control, seems that is presented only one group of these (seems always the last group in the list).
Seems that is disappeared the "ALWAYSDenyWAN" group and in this case I don't know if is only a visual bug or really the "ALWAYSDenyWAN" group is not present (obviously I can check it from the log).
Thank you
  • Maverick87
    image  Guru Member
    OK, I've checked the log and seems that both sub-groups hint the rule; so into the main group there are really two sub-groups but into the Policy Control view seems that only one group is reported (only the last in the list).
    PeterUK Posts: 4,829
    image  Guru Member
    edited October 2025
    Yes just a display limitation really I don't like the idea of doing groups in a group.
  • Maverick87
    image  Guru Member
    You're right, but I have:
    - Some IoT devices that I need to connect to internet only for firmware upgrade (only few minutes per month) — DenyInternet;
    - Some other IoT devices that never reach internet — AlwaysDenyInternet
    So I define two rules:
    - One rule (deactivated by default) that cover only the DenyInternet group, in which I allow only certain IPs and Port (to permit the upgrade);
    - One rule that deny all traffic from the both groups — this rule is defined below the other rule.
    So, in this case:
    - When an DenyInternet device try to reach internet and keep the first rule enabled, enter on this only for defined destination IPs; if the IP isn't in the allowed destination, the connection is denied by the second rule;
    - When an AlwaysDenyInternet device try to connect to internet, is always denied because hint directly the second rule.
    And obviously both device types must reach internal devices and services
    If I don't use the groups in group, I need to define more than 2 rules; one for DenyInternet allow dest ip, one for deny others dest IP, one for deny AlwaysDenyInternet type.
    You can do this better?
    Thank you
    image  Guru Member
    If that works for you I'm not going to say its wrong.
