Forticlient VPN thru USGFLEX50
umangini25362
umangini25362 Posts: 3 image  Freshman Member
Hi everyone.
I need to let my notebook connect to an external VPN on a fortigate via IPsec (FortiClient IPsec).
Everything works fine except for being at office where my USGFLEX50 seems not to let me connect to the external fortigate.
Obviously my notebook has no filters outgoing and I can see IKE packet ougoing correctly but nothing else…
Ideas?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,535 image  Zyxel Employee
    Hi @umangini25362
    You will need to ensure:
    1. If you can reach the VPN server. Please note that the protocol that FortiClient IPsec needs to be allowed on USG FLEX 50 from LAN to WAN.
    2. If it is allowed, please check the logs on fortigate to find the reason for failing.
    Zyxel Melen
    PeterUK Posts: 4,411 image  Guru Member
    If needed test without FLEX 50 to rule out other problems
  • umangini25362
    Thank you Zyxel_Melen and PeterUK for your kind answare.
    Yes: I can see IKE packet outgoing to the Fortigate correctly (but nothing more) and yes, I can mount VPN without FLEX50 in the middle.
