[USG Flex H Series] - PPPoE over VLAN - Reference
Hello everyone,
My ISP uses a PPPoE over a specified VLAN, so I need to create two interface types, one for the VLAN with DHCP (that obtain 0.0.0.0) and then a PPPoE that uses this VLAN Interface (and obtain the external IP).
Now I have some NAT/Rules/BWM/Address to do.
My question is: on what interface I need to configure this objects? On the VLAN or on the PPPoE, because seems that both uses different interface name and I can configure some services for one, and some for the other.
Why I can reference the PPPoE or directly the VLAN Interface? When do you use a reference on one interface or the other?
For example: I can use an Interface Subnet object, and I can point it on PPPoE interface or VLAN interface. Which is the best choice? Why?
As for BWM, I need to choice the VLAN or PPPoE interface as Outgoing Interface?
Hi @Maverick87
For all of configuration, please select the PPP interface. Select VLAN interface will not apply to the PPPoE interface.
Zyxel Melen1
Hi @Maverick87
Zyxel Melen1
- 241 Nebula Ideas
- 6.8K Security
- 760 USG FLEX H Series
- 381 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 521 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
