Feature Recommendations & Ideas for Future Updates Firewall H
tekkie
tekkie Posts: 11 image  Freshman Member
Hi everyone,
I’d like to share a few ideas that could make the system even better:
• NGINX Web Proxy / Reverse Proxy, similar to the well-known Docker image setup, this would be great for managing internal services securely.
• SSL-VPN with 2FA support for macOS, currently, macOS users have limited options here; native support would be a big improvement.
• WireGuard VPN Server, a modern, lightweight, and high-performance VPN protocol (the WAG project could serve as a good reference).
• Option to open log files directly from a USB stick, very helpful for troubleshooting when no internet connection is available.
These additions would significantly improve flexibility and usability, especially for professional and enterprise environments.
Best,
Valentin
1 votes
Active · Last Updated
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,651 image  Zyxel Employee
    Hi @tekkie
    NGINX Web Proxy / Reverse Proxy: Could you describe more details about this?
    SSL-VPN with 2FA support for macOS: You may try SecuExtender.
    WireGuard VPN Server: USG FLEX H supports Tailscale VPN.
    open log files directly from a USB stick: You can download the log from the device without Internet access.
    Zyxel Melen
