NWA1123-AC HD in boot loop. Hardware or software problem ?
Guillaume_21
Guillaume_21 Posts: 2 image  Freshman Member
Hello, I've a NWA1123-AC HD Access Point. It runs firmware 6.25.
When I got it, it was already not working : no Wifi network, no Web GUI access, no IP address assigned by my DHCP server.
I connected to it via console port and saw that it was stuck in a boot loop.
I succeeded at flashing the last firmware available but the boot loop is still there.
Here is the log file of the boot, my successful flash and the boot loop after the flash.
Loading...
Boot module version
Kernel version
ZLD version
CAPWAP version
DRAM size
Flash size
Ethernet MAC address
Press Ctrl-C to enter debug mode within 1 seconds...
Startup canceled
NWA1123-AC-HD>
NWA1123-AC-HD> atna 192.168.1.2
OK
NWA1123-AC-HD> atns 192.168.1.103
OK
NWA1123-AC-HD> atnz 625ABIN9C0.bin
Reading 192.168.1.103:625ABIN9C0.bin: Done. 23962248 bytes read
header_len = 652, 108, 272, 2
translate_header: i = 0, type = 2, flag = 0, file_len = 2424832, chk_sum = ec390b2a, offset = 40000
translate_header: i = 1, type = 3, flag = 0, file_len = 21536768, chk_sum = 6cd6f283, offset = 290000
0x44e1 vs 0x44e1
checksum = 0x8b9c3d8a, signature = 0xdeadbeaf
total_len = 0x016da288, version = 0x00000100
max_model = 0x00000005, file_num = 0x00000002
head_len(R) = 0x00000108, head_len = 0x00000108
info_len(R) = 0x00000272, info_len = 0x00000272
file_offset = 0x00000648
model = 0044e1 00ffff 00ffff 00ffff 00ffff
capwap version = undefined
model_id = NWA1123-AC-HD
0, kernelnwa1123-ac-hd.bin, TYPE_KERNEL, kernel, 2.6.36, 2022-03-30 10:54:03, 2424832, ec390b2a, 40000
1, squashfs_ro.img, TYPE_CODE, zldfs, 6.25(###.9), 2022-03-30 11:12:07, 21536768, 6cd6f283, 290000
Firmware upgrading...
cal_file_offset: i = 0, offset = 648, len = 0
image_name = flash0.kernel2, file_len = 24fe00, skip = 488
Programming...done. 2424320 bytes written
cal_file_offset: i = 1, offset = 2425480, len = 2424832
image_name = flash0.fs2, file_len = 148a000, skip = 250288
Programming...done. 21536768 bytes written
Programming...done. 512 bytes written
Firmware upgrade done.
NWA1123-AC-HD> atsr
Loading...
Boot module version
Kernel version
ZLD version
CAPWAP version
DRAM size
Flash size
Loader:raw Filesys:raw Dev:flash0.kernel2 File: Options:console=ttyS0,115200 root=/dev/mtdblock8 init=/sbin/zyinit rootfstype=squashfs mtdparts=bcmsflash:256k(bootm),2368k(backup_ker),25344k(backup_fs),4608k(conf),64k(mrd),128k(nvram),2432k(recovery),2368k(kernel),25344k(zldfs),2048k(coredump),64k(mrd_reserved),512k(disklog); loglevel=1 bootImage=1
Starting kernel...
..board_fixup
board_fixup: mem=256MiB
board_map_io
board_init_irq
board_init_timer
board_init
system 2.6.36.4brcmarm
Loading...
Boot module version
Kernel version
ZLD version
CAPWAP version
DRAM size
Flash size
Loader:raw Filesys:raw Dev:flash0.kernel File: Options:console=ttyS0,115200 root=/dev/mtdblock2 init=/sbin/zyinit rootfstype=squashfs mtdparts=bcmsflash:256k(bootm),2368k(kernel),25344k(zldfs),4608k(conf),64k(mrd),128k(nvram),2432k(recovery),2368k(backup_ker),25344k(backup_fs),2048k(coredump),64k(mrd_reserved),512k(disklog); loglevel=1 bootImage=0
Starting kernel...
..board_fixup
board_map_io
board_init_irq
board_init_timer
board_init
Is it a software problem or, more problematic, a hardware problem ?
As the device is EOL, I guess I couldn't make it repaired if it's a hardware problem.
Thanks in advance for your answers.
  • Zyxel_Tina
    Zyxel_Tina Posts: 642 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @Guillaume_21,
    Given that the NWA1123-AC HD has reached its EoL, support for this product is limited. We recommend trying to resolve the issue by performing a factory reset. If the problem persists after the reset, we suggest considering our newer access point solutions to ensure the security and performance of your network.
    Wireless | Zyxel Networks
    Zyxel Tina
  • Zyxel_Tina
    Hi @Guillaume_21,
    Zyxel Tina
