ZyXEL P-2000W_V2
asylon
asylon Posts: 2 image  Freshman Member
What battery is compatible with the ZyXEL P-2000W_V2? Where can I buy a genuine battery?
  • Zyxel_Tina
    Zyxel_Tina Posts: 401 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 50 Answers First Comment
    Hi @asylon,
    Thank you for reaching out to the community. After reviewing your inquiry, we would like to clarify that the product you mentioned is not a Zyxel Networks-supported device. Because of this, we are unable to provide technical support or assistance for that equipment.
    Zyxel Tina
  • mMontana
    mMontana Posts: 1,443 image  Guru Member
    This image comes from the uploaded file.
    I think the phrase "is not a Zyxel Networks-supported device" instead of a End of support declarement is really interesting.
