[USG Flex H] - Export to external services some usefull metrics
Hello everyone,
I've a domotic house, in which I have Home Assistant as my central hub to manage curtrains, lights, networks devices, electrical plugs and so on.
It's interesting to have some metrics on about the network performances, external WAN IP, how many devices are connected, and somethings help to manage the network on one hub.
It's also interesting try to manage some function directly from the hub (restart network, restart WAN interface, or somethings else)
Can be an idea to export all those metrics in any manner out from the firewall? Or Nebula just expose somethings similar?
Thank you
Hi @Maverick87
Home assistant seems can use SNMP to get device's info and use automantion to display with visual. However, we are not familier with home assistant, you might need to investigate it yourself.
Zyxel Melen0 -
@Zyxel_Melen an easy accessible MIB file with documentation could be useful for managing SNMP data.
Hi @Zyxel_Melen ,
You're right, I've explored now the SNMP Info with SNMPWalk.
I've all the OID, but I don't have the mapping between an "human-readable" name and the OID referred.I've downloaded also the MIB Files but isn't usefull, there isn't a key-value map for map the OID and what are the key referred.
You have a guide or manual about how to map the OID?
Thank you
- 217 Nebula Ideas
- 583 USG FLEX H Series
- 297 Service & License
- 476 News and Release
