[Release Note] Zyxel Access Point - V7.20 Patch 3 firmware has been released
Zyxel_Melen
Zyxel_Melen Posts: 4,535 image  Zyxel Employee
edited October 2025 in WirelessLAN New Release
BE Series Access Points Firmware Release Note
October 2025
Overview
This document provides firmware release information on Zyxel Access Points platforms, introduce new Access Points, new features and enhancements, bug fix, known issues and workarounds information for Release V7.20 Patch 3 C0.
Supported Platforms
(Click Hyperlink to download the firmware directly)
WiFi 7 model(s):
Zyxel WBE660S - V7.20(ACGG.3)C0
Zyxel WBE630S - V7.20(ACLW.3)C0
Zyxel WBE530 - V7.20(ACLE.3)C0
Zyxel WBE510D - V7.20(ACLX.3)C0
Zyxel NWA210BE - V7.20(ACLY.3)C0
Zyxel NWA110BE - V7.20(ACLZ.3)C0
Zyxel NWA130BE - V7.20(ACIL.3)C0
New Features and Enhancements
N/A
Bug Fix
C=Cloud mode, M=Managed, S=Standalone mode
Bug fixCMS
1. [eITS: 250800183, 250800762 250800398, 251000090] [Symptom] WiFi 7 AP unexpected memory handling affect system stability (System event occurred).VVV
2. [RMID: 64327] [Symptom] When some clients disconnect, incorrect MAC or MLO information may appear in logs or client status.VVV
Known Issue
Known IssueCMS
1. [SPRID: 240913082] [Symptom] Stations cannot authenticate when an SSID is configured with MLO (4G+5G bands) and the security mode is set to WPA3 with MAC Authentication via RADIUS.V--
2. [SPRID: 241216264] [Symptom] When the WAC5302D-Sv2 model is used as the Root in a Mesh setup, and WiFi 7 series models with firmware versions 00 & 10 are used as Repeaters, the Mesh Known issue Cloud Managed Standalone connection cannot be established.V--
3. [SPRID: 241219350] [Symptom] The wireless monitoring data exhibits abnormal behavior.V--
4. [SPRID: 250402043] [Symptom] When an MLO client connects to the SSID, the authentication field of client page does not display voucher.V--
5. [SPRID: 250402050] [Symptom] Under this configuration combination : Sign-on with my RADIUS enabled along with MAC authentication fallback. The behavior of MLO clients after connecting may not be as expected: a. Traffic does not pass through (no connectivity). b. Client remains online after reconnecting, even without re- authentication. c. After completing MAC authentication, the client is redirected to the captive portal.V--
6. [SPRID: 250627398] [Symptom] 5G radio is 11be mode + MLO enabled + security is enhance open, after wireless client which support enhance open security connected the SSID field of client list will show SSID name(transition Known issue Cloud Managed Standalone mode).VVV
7. [SPRID: 250714115] [Symptom] After the wireless STA connects to the initial SSID, the AP's web GUI is accessible, but pinging the AP's IP address fails.VVV
8. [SPRID: 241106062] [Fast Roaming] [Symptom] The station experienced a disconnection caused by a reauthentication failure that occurred immediately after its first fast roaming event.V-V
9. [RMID: 62239] [Symptom] The access point may reboot unexpectedly when the 2.4GHz radio is configured in BE mode. To prevent this, the 2.4GHz radio mode has been converted to AX mode.VVV
Limitation of Settings
1. [SPRID: 241203097] [Symptom] When the Mesh topology consists of a non-supported MLO Root combined with MLO Repeater Hop1 and Hop2, it may affect the Repeater's downlink and cause issues with the service VAP lacking MLO functionality.
Zyxel Melen
  • Zyxel_USG_User
    Zyxel_USG_User Posts: 113 image  Ally Member
    First Answer First Comment Friend Collector First Anniversary
    edited October 2025
    After I installed the newest firmware on the new AP, the speed and stability have dropped tremendously.
    The device is a
    NWA50BE PRO, now on firmware V7.25(2)
    I need to reinstall the V7.25(1) which was stable and OK compared to the newest.
    On the download portal / library, there is only a much older version available for downloading, see here V7.20(*)
    https://www.zyxel.com/global/en/support/download?model=nwa50be-pro
    Testing the bandwidth with any internet speed tests, but also monitoring the sending power on 2.4/5/6 show after the firmware update huge fluctuations in bandwidth.
    Just connecting to the AP brings to most client devices the notification that the internet connection is unstable. All this did not happen with the previous firmware, which I used approx. 1 month.
    The internet connection is working perfectly fine and constantly for the devices using wired network, whilst anything connected to the WiFi shows unstable internet connection. Instead of full signal, there are also only 2 stripes of signal strength now, previously signal was full.
    Where can I find the previous firmware to download and downgrade the firmware?
    Just in case- are there any pre-requirements or a special procedure to go through, for the firmware downgrade back to the stable version?
  • Zyxel_Melen
    Hi @Zyxel_USG_User
    We checked the first firmware of NWA50BE is 7.20 P1. Therefore, you may download it from the download library. To downgrade the firmware, you only need to log in to the AP and do a firmware upgrade to the previous firmware version.
    Before you downgrade, could you help share some details of this issue with us?
    1. The diagnostic file when the poor signal issue occurs.
    2. The result of testing the bandwidth with any internet speed tests and the output power.
    Thanks~
    Zyxel Melen
  • Zyxel_USG_User
    I want to install the FW version PRIOR to this latest version, unfortunately I did not take a printscreen prior to updating.
    There are so many flavours of the firmwares, with different endings! The ftp server also shows a very old build.
    The device came with 7.20 and it updated automatically to the latest version prior to this current latest version. That version was stable and we had no problems with it.
    Basically, after installing the firmware, the clients started complain that the Wifi connection is unstable. When I use tools on a desktop or the smartphone which I used for years, I have an entirely new warning saying that the connection is unstable. The internet connection is a business connection, very stable and is monitored in terms of LSA so the internet connection per se is not the problem.
    Please write what do I have to do to save the logs or debugs etc.
  • Zyxel_Melen
  • Zyxel_USG_User
    Hi and thanks for the replies. I think this is not the firmware which I am looking for. The device had the version 7.20 installed, then updated to another intermediate version which was working well. When I saw the announcement with another patch towards end of October 2025, I immediately updated the AP to the newest version. Immediately, all clients started notifying that the connection may be unstable. Some refused to connect due to the quality of the connection.
    No configurations were changed on the AP, or on the Zyxel firewall which acts as GW. The clients were not changed either.
    Even if I connect, when testing the connection quality and bandwidth, this app which I use since years shows a yellow 'go' ring which never ever happened before. Now, I get the 'blue' ring for stable connections only from the wired clients. Internet connection is a business line, with SLA etc. and very stable.
    Clients are: MacOSs, Win11s, iPads, iPhones and Androids.
    As soon as I get the possibility, I will create the logfile / debug file and send it via mail to you.
  • Zyxel_USG_User
    Here is one of the apps also noticing the unstable connection with the smartphones connected via the AP to the stable business internet:
    https://www.speedtest.net/
    The ring around 'GO' gets immediately orange with the notification that the connection may be unstable. With standard to good quality connection, the ring is green-blue-turquoise colour from the loading of the app, and stays permanently on with this colour.
  • Zyxel_USG_User
    edited November 2025
    OK, got to log onto the AP. The current version of the nwa50be pro is:
    V7.25(2)
    I need the version V7.25(1), if that version was the previous one and exists.
    I am now collecting the debugging and will send it via the portal messaging to you, Zyxel_Melen.
    Edited: I sent the message with two debug files.
  • Zyxel_Melen
    Update:
    After checking, we confirmed that the @Zyxel_USG_User issue on NWA50BE PRO is not related to the firmware version, but related with the AP uplink ethernet cable.
    Users who use NWA50BE PRO, please feel free to upgrade your device's firmware. If you have any problems, please raise your question in the Wireless category or the Nebula category. Thanks!
    Zyxel Melen
  • Zyxel_USG_User
    Thank you Zyxel_Melen for supporting us with tests from your side, so that we could find the culprit!
