Protect the link between the firewall and the switch
Elgen07
Elgen07 Posts: 8 image  Freshman Member
Hi
I’m using MAC authentication on a GS1920-24 switch to prevent unauthorized devices from connecting to it. However, I can’t use MAC authentication on the uplink to the firewall. How can I ensure that only the firewall can connect to the switch, and only the switch can connect to the firewall? The firewall is a USG FLEX 100.
Best regards,Olav
    PeterUK Posts: 4,411 image  Guru Member
    edited October 2025
    There is no way I see you can do this you could ACL the source MAC of the FLEX 100 LAN gateway or/and add all the destination MAC clients. Or to make it so that no untag device can connect to the FLEX 100 by using a VLAN.
    But the idea is no one would have access to the uplink.
    I guess what you want is to encrypt the the link? Interesting idea such that packets are encrypted and can only be decrypted by matching key.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,533 image  Zyxel Employee
    Hi @Elgen07
    Normally, the firewall and core switch should not be easy to touch. May I know where did your place?
    For the function to prevent unauthorized devices, you can enable MAC authentication on the switch only if no other device is connected to the firewall on the same interface. On the firewall, there is no option to achieve it.
    Zyxel Melen
  • Elgen07
    Thanks for your reply — you pretty much confirmed what I feared. However, perhaps it would be a good idea to secure the link between the firewall and the switch.
    Best regards,Elgen
    edited October 2025
    Or you can get another USG and do a VTI so that where the switch is you have a short link to this other USG then VTI to the main USG
  • zyman2008
    zyman2008 Posts: 242 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    edited November 2025
    I think a option way is to enable LACP on the firewall and switch.
    At least, it can restrict peers to having LACP functionality in order to connect, generally not the case for user computers or switches without specific configuration.
    To support layer 2 encryption like MACSec is perfect but it need specific hardware chip to support encrypt/decrypt on high speed link. MACSec support is typically only seen in enterprise-level products. Because of the higher cost, these products are also quite expensive.
