Accented characters in SSID
l_archipretre
l_archipretre Posts: 5 image  Freshman Member
I'm deploying NWA50BE in France in an installation using a router from Orange where it is possible to have accented characters in the SSID - e.g. <l'archiprêtré_invités>
It would be good to be able to use the same SSID on the AP.
Best.
-Graham "l'archiprêtre" -
3 votes
Active · Last Updated
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,651 image  Zyxel Employee
    Hi @l_archipretre
    May I know if you get the error message that said length must be 1-32 characters long?
    If so, please try the punycode in SSID first. The punycode of "l'archiprêtré_invités" is "xn-- l'archiprtr_invits-mzbgm".
    Zyxel Melen
  • l_archipretre
    There is no error message - the accented characters are replaced by other characters (I cannot connect to the AP now, I'm at a different site) I remember  and © etc.
    As soon as I'm back I'll re-test.
  • Zyxel_Melen
    Hi @l_archipretre
    Thanks for sharing. I checked that Nebula hasn't support utf-8 code, which device's firmware is already supported. We will monitor the comments and vote on this idea to evaluate it.
    Additionally, here is the result of the punnycode:
    Zyxel Melen
