[USG Flex H] - Wrong SNMP Value for CPU Core 3/4 (FastPath dedicated CPUs)
Maverick87
Maverick87 Posts: 544
Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate
image  Guru Member
Hello everyone,
I have an USG Flex 200HP and I'm using SNMP Protocol for create an usage dashboard in Home Assistant.
I've successfully read the CPU Load counter, but seems that for the Core 3 and Core 4 I show always 100% load, instead a lower values.
The OID is:
  • CPU Core 3: 1.3.6.1.2.1.25.3.3.1.2.196610
  • CPU Core 4: 1.3.6.1.2.1.25.3.3.1.2.196611
Can you give me some explanation about this?
Thank you
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,284
    image  Zyxel Employee
    edited October 2025
    Hi @Maverick87
    May I know if core 3 & 4 always 100% load if you polling these OIDs?
    Update:
    The design of USG FLEX H (fastpath) leads the public mib of the CPU usage gets the wrong info. Please use our private mib file to get the correct info.
    Zyxel Melen
  • Maverick87
    image  Guru Member
    edited October 2025
    Hi @Zyxel_Melen ,
    Yes, if you poll these OID:
    The CPU Core is always 100%
    There are also the OID for Core 1 and Core 2 (I think "slow path") and in this case the values are correct:
    • CPU Core 1: 1.3.6.1.2.1.25.3.3.1.2.196608
    • CPU Core 2: 1.3.6.1.2.1.25.3.3.1.2.196609
    I know that there is the CPU Usage but is a cumulative CPU Load, instead I'm curious to have (if possible) the separated CPU Load (also because in the Maintenance GUI I have the CPU Load per core and in this case the values are correct — CPU Core 3-4 are the real values not always 100%).
    Seems that you have also the CPU Usage for Fast Path (sysMgmtFPCPUUsage) on the private MIB, but also in this case, the information is cumulative and not splitted by Core.
    Can you correct the values on the CPU Core Fast Path? These OID:
    Thank you
  • Zyxel_Melen
    Hi @Maverick87
    Thanks for your update. Let us check what we can improve here. I will keep you posted.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Maverick87
    Currently the fast path CPU usage can be checked by the private MIB sysMgmtFPCPUUsage. This OID will provide the average of the fast path CPU (core 3, 4) usage.
    Zyxel Melen
  • Maverick87
    image  Guru Member
    Hi @Zyxel_Melen ,
    OK thank you, so is not possible to know the single value of the Cores?
    Thank you
  • Zyxel_Melen
    Hi @Maverick87
    I'm checking with our team and I will update you once I get further information.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Maverick87
    Our team received your requirement and I have created the idea post.
    USG FLEX H fast path CPU usage OID display single core usage — Zyxel Community
    We will monitor the comments and votes to evaluate this idea.
    Zyxel Melen
