NWA50AX and NWA1123 AC
robyone33
robyone33 Posts: 2 image  Freshman Member
Hi everyone, I have a Zyxel NWA1123 AC, and these two features are very useful:
An antenna button, to allow for ceiling or wall installation, changing the antenna radiation from vertical to horizontal depending on the access point's positioning.
An Ethernet output port for extending the network via cable.
The new NWA50AX does not have an antenna button or a second Ethernet port.
Regarding the antenna, it seems the button switch has been replaced by a software setting, but I'm not sure.
Regarding the second Ethernet port, if I wanted it, which model should I choose?
Can you please help me?
  • Zyxel_Tina
    Zyxel_Tina Posts: 642 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @robyone33,
    Welcome to Zyxel Community!
    Antenna Switch
    • The NWA50AX does not support this feature, neither via hardware nor software, due to its different antenna design.
    • Currently, the button has indeed been replaced by a software setting in the GU on some of our models. These include the WAX510D, WAX610D, and WAX620D-6E, and WBE510D. For detailed configuration instructions, please refer to the specific model's user guide available in the download library.
    Second Ethernet Port
    The NWA50AX only has one Ethernet port, while many other models offer multiple Ethernet ports, including: WAX610D, WAX620D-6E, WAX630S, WAX650S, WAX640S-6E, WBE660S, NWA130BE, NWA210AX, NWA220AX-6E, WAC500H / WAX300H
    Considering your need for both the Antenna Optimization feature and multiple Ethernet ports, the WAX610D would be the suitable model for you to try.
    Zyxel Tina
  • Zyxel_Tina
    Hi @robyone33,
    Antenna Switch
    Zyxel Tina
