USG Flex H series - internal radius server for WLAN auth
mjr
mjr Posts: 40 image  Freshman Member
First Comment Friend Collector Eighth Anniversary
on the previous USG Flex series it was possible to use the internal user database for WLAN auth. (Configuration - System - Auth. Server - Trusted Clients)
On the new USG Flex H series this feature seems not to be available this time. Please put it on the roadmap.
Best regards, MJR
2 votes
Active · Last Updated
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,602 image  Zyxel Employee
    Hi @mjr
    H as AP controller supports to use internal authentication server to authenticate 802.1X.
    Do you mean you need the "Trusted Clients" function to authenticate your clients?
    Zyxel Melen
  • mjr
    Ticket: 537004
    customer has NWA210AX and a USG Flex 700
    customer upgrades to a USG Flex 700H
    NWA210AX are cloud managed via Nebula - SSID - WPA Enterprise with USG Flex 700 as internal radius
    USG Flex 700H seems to be missing this feature.
    https://support.zyxel.eu/hc/en-us/articles/27904878600722-Which-Access-Points-Are-Supported-by-Different-Zyxel-AP-Controller-Models
    the NWA210AX is not supported by USG Flex 700H as controller.
  • Zyxel_Melen
    Hi @mjr
    Thanks for the details! I will let our product team know this requirement. Additionally, we will monitor the comments and votes of this idea to evaluate.
    Zyxel Melen
  • mjr
    is this feature now availabe in the 1.37 version of the USG Flex 700H?
  • Zyxel_Melen
    Hi @mjr
    Thank you for following up on this request.
    After reviewing our development roadmap, this feature is not yet included in V1.37, as we are currently prioritizing several concurrent development efforts. However, please rest assured that your request has been documented in our feature backlog and remains under consideration for future releases.
    We appreciate your patience and continued feedback.
    Zyxel Melen
