VPN encryption algorithms missing Flex 200H (USG FLEX H series)
SDimitri
SDimitri Posts: 6 image  Freshman Member
edited October 2025 in USG FLEX H Series
Hello! I have a problem with encryption on my Flex 200H. In VPN setting I see des/sha1 only, everything else like sha-256, sha-384 etc i'm not see. On Flex 500 i'm decide this question with "crypto algorithm-hide disable" over ssh, but here it doesn't worked.
How i can decide my problem in new Flex 200H? Besides, on Zyxel website in demo mode of Flex 200H web gui i saw all encryption algorithms and thought that in my Flex 200H were like on demo gui.
  • Zyxel_Tina
    Zyxel_Tina Posts: 701 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @SDimitri,
    On your USG FLEX 200H, the command crypto algorithm-hide disable is not applicable for displaying hidden VPN encryption algorithms.
    To enable all VPN encryption algorithms, including SHA-256 and SHA-384, you need to use the following commands in the firewall's CLI:
    1. Check for hidden crypto algorithms using: usgflex200h> show ipsec hidden-crypto
    2. Make these hidden algorithms visible and selectable in the VPN settings, execute: usgflex200h> cmd ipsec display hidden-crypto enable false
    After running this command, you should see the full range of encryption algorithms available in your Flex 200H's VPN settings.
    Zyxel Tina
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    edited October 2025
    Hi @SDimitri
    This issue is unusual and we need to check with our team. We will update you once we get further information.
    Zyxel Melen
  • Zyxel_Tina
    Hi @SDimitri,
    Zyxel Tina
  • SDimitri
    Hello @Zyxel_Tina
    Thank you so much! This instruction helped me!
    Have a nice day!
