Can the 10Gb/SPF+ Ports Auto-Negotiate lower link speeds?
checkyourmirrors
checkyourmirrors Posts: 2 image  Freshman Member
I am looking at getting the XGS1250-12 and three XMG-108's and my hope would be to use the 10Gb ports for up/downlinks. How IF my wiring distance is an issue will the port auto-negotiate down to 2.5Gb? or 1Gb?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,533 image  Zyxel Employee
    edited November 2025
    Hi @checkyourmirrors
    If you connect these switches via SFP port, the wire distance should check the transceiver's limitation. If the distance over the max distance, the link will be down.
    Please reference the supported transceivers of XGS1250-12 and XMG-108 in below sheet:
    Zyxel Melen
