Zyxel SCR 50AXE Stop Working 2.4Ghz wifi after upgrade to V1.20(ACGN.0)
Lau13
Lau13 Posts: 2 image  Freshman Member
I upgraded my Zyxel SCR 50AXE to the latest version (V1.20(ACGN.0)), and after that, my 2.4GHz Wi-Fi network stopped working. Sometimes it appears, sometimes it doesn’t, and when I try to connect, it gives an error. It also shows a Wi-Fi network named “SSID,” but I think that was already there before the upgrade.
Has anyone experienced any bugs with this version?
Thanks in advance.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    edited November 2025
    Hi @Lau13
    I replicate this issue with V1.20(ACGN.0), but there's no issue. The SSID is visible and can connect to it.
    Could you share the error message with us so we can better check this issue? And what device did you use to connect? Please help to check its WiFi generation and share with us.
    The Wi-Fi network named “SSID,” is not the default SSID name of the SCR50AXE, therefore, it is more likely an SSID from other devices.
    Zyxel Melen
  • GiuseppeR
    GiuseppeR Posts: 664 image  Master Member
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
    Hi @Lau13
    I have similar issues with latest firmware for security routers, regarding WPA2 and old WiFi cards.
    Which devices are you trying to connecto to "old" 2.4 GHz band?
