GS1350-6HP Cheapest "Outdoor" Switch?
Hi
I need some Pis in my Garden to Measure some things. For that I need Ethernet where I put a Cable there already. We have a very small Greenhouse where I can put a Plastic Box with that Drying Balls inside and an Air Valve who let the moist Air out and Clean Air in.
So the Box will not "explode". The only problem is in Winter it get Cold. So I would need a Switch who can withstand that. I looking into the Zyxel Page since my hole Network is made up Zyxel Switches and I found this one: GS1350-6HP
It can go down to -20C who is way enough here and have PoE for a Cam.
So is it the cheapest L2 PoE Switch from Zyxel?
Thanks!
Best Answers
The GS1350-6HP device is an excellent choice for your outdoor setup. It is a Layer 2 PoE switch designed for surveillance applications, and its operating temperature range down to -20°C makes it suitable for your needs. It also offers 802.3bt PoE on ports 1 and 2, providing higher power for devices like cameras.
Zyxel Tina
Regarding your inquiry about
GS1350-6HP Cheapest "Outdoor" Switch?I'd like to kindly clarify that according to the official specifications, this switch is not classified as an "outdoor" unit. However, it can still fulfill your usage scenarios effectively.
For more detailed information, please refer to the specification datasheet here.
Zyxel Tina
Would seem so or there is the XMG-105HP that is Unmanaged but note it will only link down to 100Mb should you have a device that only link at 10Mb
I saw them very cheap used on Ebay. Are there older Version who are missing some features the current Version have?
I want them L2 to see what device are recognisable.0 -
Zyxel Tina
Zyxel Tina
- 588 USG FLEX H Series
- 477 News and Release
