XMG1915-10EP: unable to adjust POE settings
I recently reverted to the standalone mode (mostly because I found the Nebula interface waaaay too busy).
In the Nebula mode, I was able to adjust the POE modes (af, at and BT) as well as monitor the power usages.
Was it some thing that was ONLY available in the Nebula mode ?
Also, how can I relaunch the wizard initial configurator.
Many thanks ! 😉
Hi @brucebarelly,
Welcome to Zyxel Community!
In standalone mode, your XMG1915-10EP switch allows you to adjust PoE settings and monitor power usage directly through its local web interface. To configure PoE modes (af, at, and bt), navigate to PORT > PoE Setup in the web GUI. Here, you can set the "Power up mode" for individual ports to the desired 802.3af, 802.3at, or 802.3bt standard. You can also implement PoE schedules by first defining time profiles under SYSTEM > Time Range and then applying them via PORT > PoE Setup > PoE Time Range Setup.
However, if the device is running cloud mode, the configuration option will be limited. Therefore, please remove the device from the organization first.
Zyxel Tina
Hi @brucebarelly,
Zyxel Tina
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
