VPN encryption algorithms missing Flex 200H (USG FLEX H series)
Hello! I have a problem with encryption on my Flex 200H. In VPN setting I see des/sha1 only, everything else like sha-256, sha-384 etc i'm not see. On Flex 500 i'm decide this question with "crypto algorithm-hide disable" over ssh, but here it doesn't worked.
How i can decide my problem in new Flex 200H? Besides, on Zyxel website in demo mode of Flex 200H web gui i saw all encryption algorithms and thought that in my Flex 200H were like on demo gui.
Hi @SDimitri,
On your USG FLEX 200H, the command crypto algorithm-hide disable is not applicable for displaying hidden VPN encryption algorithms.
To enable all VPN encryption algorithms, including SHA-256 and SHA-384, you need to use the following commands in the firewall's CLI:
- Check for hidden crypto algorithms using: usgflex200h> show ipsec hidden-crypto
- Make these hidden algorithms visible and selectable in the VPN settings, execute: usgflex200h> cmd ipsec display hidden-crypto enable false
After running this command, you should see the full range of encryption algorithms available in your Flex 200H's VPN settings.
Zyxel Tina
Hi @SDimitri
This issue is unusual and we need to check with our team. We will update you once we get further information.
Zyxel Melen0 -
Hi @SDimitri,
Zyxel Tina
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
