PHY Debugging
Cassios
Cassios Posts: 2 image  Freshman Member
How can I read the MII registers from ES3500-24 switch.
In Cisco swicthes I can easily do it using the "phy" suffix option , but I cant figure it out for the ES3500.
Thanks!
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @Cassios
    Since the ES3500-24 model has reached its End of Life (EOL) status, which means our support for this model will be limited. For optimal performance and support, we recommend exploring our current switch offerings here: Switch | Zyxel Networks
    Zyxel Melen
