IP Spoofing Control and IPsource guard
hi.
I have set up IP spoofing control on my USG flex h which seems to work well but when I try and set up IPSG on my nebula controlled switches I get some switches disconnecting from nebula and clients been blocked even if I don’t have any ports selected.
I’ve added them to the list of allowed clients but it doesn’t seem to fix the issue.
Do I have to set it up in a particular order first? And Is it necessary to have both turned on or is it sufficient just to use the protections on the Zywall?
Hi @JimboJambo
IP Spoofing Control and IP source guard can be enabled at the same time. The issue you encountered should be misconfiguration.
Here are some FAQs for you to reference:
Understanding and Configuring IP Source Guard in Nebula switch — Zyxel Community
What should be noted when setting IP Source Guard - DHCP Snooping trust? — Zyxel Community
Zyxel Melen0
- 441 Beta Program
- 529 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
