How can i reset a wax620 to factory defaut
I got an use one with no information over it, how can i reset it to factory default.
Hi @Schneewittchen,
Welcome to Zyxel Community!
You can factory reset your WAX620-6E by pressing the reset button.
Locate the reset button on the back of the WAX620. With the device powered on, use a paperclip or a similar pointed tool to press and hold this button for more than 5 seconds. Release the button once the Power LED begins to blink. The WAX620 will then reboot, which may take a few minutes, restoring all settings to factory defaults.
Zyxel Tina
Hi @Schneewittchen,
Zyxel Tina
- 216 Nebula Ideas
- 570 USG FLEX H Series
- 343 Security Ideas
- 295 Service & License
- 471 News and Release
