[USG FLEX H Series] - NTP Server
Maverick87
Maverick87 Posts: 114 image  Ally Member
Hello everyone,
Is it possible to use the USG Flex H as an NTP server?
This way, I wouldn't need to expose my devices to the internet to synchronize their clocks, but the current time/timezone information would come directly from the firewall, as the only true time source.
Thank you,
  • Zyxel_Tina
    Zyxel_Tina Posts: 724 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @Maverick87,
    The USG FLEX H series can function as an NTP server for your internal devices. You can configure this via the CLI with the following commands:
    >edit running
    >running config# / vrf main ntp server-subnet <priority> {allow| deny}{CIDR subnet| all}
    >running config# commit
    >running config# copy running startup
    >running config# exit
    Replace CIDR subnet with the specific subnet you want to allow to synchronize with the firewall. You can also use all to permit all subnets to synchronize with this device.
    For example, / vrf main ntp server-subnet 0 allow 192.168.1.0/24 or / vrf main ntp server-subnet 1 allow all
    Zyxel Tina
    PeterUK Posts: 4,451 image  Guru Member
    Currently does not look like you can best you can do is run a box with OS that can if needed you might need this done on USG.
    edit running
    vrf main ntp maxdistance 16
    commit
  • Maverick87
    OK, so you suggest to use an external OS (Raspberry/Linux/Windows) to use as NTP Server?
    Yes I just use windows
  • Zyxel_Tina
    Hi @Maverick87,
    >edit running
    Zyxel Tina
  • MassimilianoDelta
    MassimilianoDelta Posts: 28 image  Freshman Member
    edited February 16
    Hi Tina
    thanks for your support.
    Now it works correctly
    By Max
