[USG Flex H Series] - Internal NTP Server
Hello everyone,
as a new feature request, can be usefull to install an NTP Server inside the USG Flex H firewall.
In this way, if you block internet connection for a device, it can synchronize own clock/timezone information directly from the firewall without using internet at all.
The NTP Server can also used as time source for all the devices, as single point of truth.
Thank you
Hi @Maverick87,
Thank you for your input!
Regarding your request, you can configure the USG FLEX H firewalls to function as an NTP server for your internal devices via the CLI using the following commands:
>edit running
>running config# / vrf main ntp server-subnet <priority> {allow| deny}{CIDR subnet| all}
>running config# commit
>running config# copy running startup
>running config# exit
Replace
CIDR subnetwith the specific subnet you want to allow to synchronize with the firewall. You can also useallto permit all subnets to synchronize with this device.For example,
/ vrf main ntp server-subnet 0 allow 192.168.1.0/24or/ vrf main ntp server-subnet 1 allow allZyxel Tina
Cool so you can😎
Maybe a simple checkbox in the UI per interface in advanced settings would make this easy.
Cool, it works like a sharm!!
As PeterUK says, can be implemented a checkbox in the interface for enable/disable this functionality? I think that can be enabled/disabled for all the interfaces, because you can always choice what is the server that work as NTP Server.
Hi @PeterUK and @Maverick87,
Thanks for your feedback! We'll be monitoring the votes and comments as part of our evaluation process.
If anyone likes this idea, please show your support by leaving a comment or voting for it.
Zyxel Tina
Hi @Zyxel_Tina,
do you have an ETA about this idea? Can be implemented a flag to enable/disable NTP Server feature?
Thank you
Hi @Maverick87,
The feature has not been determined yet. We'll continue monitoring the votes and comments to assess and prioritize this request.
We appreciate your patience and understanding!
Zyxel Tina
- 244 Nebula Ideas
- 6.9K Security
- 798 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 531 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 124 Security Highlight
