EOL bug in VPN300 port group
PeterUK
PeterUK Posts: 4,446 image  Guru Member
edited November 2025 in Security
VPN300 V5.37(ABFC.2)
So not expecting this to be fixed just thought I share the problem.
So this is the default each port is not shared or linked to another
At one point I moved P6 to Ge3 so that P3 and P6 are under that interface all worked fine. Then I want to move P6 back to Ge6 which worked but firewall was allowing traffic on a new zone (or even none) with no firewall rule to allow the traffic.
The solution was to reboot the VPN300 then it works correctly.
