Issues with built-in Wi-Fi and Guest VLAN after upgrading FLEX50W to firmware 5.41(ABAR.0)
Hi Folks,
After upgrading the firmware of a ZyXEL FLEX50W to version 5.41(ABAR.0), the built-in wireless has become unstable. Additionally, the guest wireless network, which is associated with VLAN 9 and has a configured DHCP pool, no longer assigns valid IP addresses to wireless clients.
Is there any patch or known fix available to resolve these issues?
Thanks in advance.
Best regards,
Hi users,
This issue has been addressed, and we will fix it in the next firmware release.
Zyxel Tina
Hello Tina,
issue solved with WK46 patch
https://support.zyxel.eu/hc/en-us/articles/360005438274-Weekly-Firmware-Support-Version-Lab-Version
Thank you
Best regards0 -
We have installed WK46 patch but users are now complaining about unusably slow Wi-Fi connection. Wi-Fi works now but slowness makes it unusable.
Now that v5.42 ABAR0 is out, has anyone upgraded yet to see if this issue is fixed?
Per the release notes:
Modifications in V5.42(ABAR.0)C0 - 2026/01/22
[On Premises mode]
10. [Bug Fix] eITS#251002189
a. Fix: DHCP does not work for Built-in AP.0 -
[On Premises mode]
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
ZCNE Certified
