Option to deactivate "Admin" user
Since we can create other users with Privilege level 14, it would be nice if we could enable / disable the default "admin" account (From a privilege level 14 account).
Hi @mietz,
You can change the administrator account's username from "admin" to the name you prefer when the running firmware version is 4.90 or a newer version. Below is an example of GS1350 running the 4.90 firmware version.
For the other switch model, please stay tuned on the category "switch new release."
Zyxel Melen0 -
Hi @Zyxel_Melen
Is there any ETA for a Firmware providing this feature to XS1930 series?
Best regards
Hi @p4nd4
Thank you for your inquiry about this feature for the XS1930 series.
I'm still clarify with our team, and I will update the result here once I get further info. Thanks.
Zyxel Melen0 -
Hi @p4nd4
The current firmware for the XS1930 series has demonstrated solid stability and compatibility, so there is no urgent need for a new release at this stage.
We will continue to maintain the product based on its actual operational status.
Zyxel Melen1 -
Hi @Zyxel_Melen
Thank you for the information.
It's good to hear that the XS1930 series will continue to be maintained / supported. This at least opens up the possibility that this feature could be implemented in a future firmware update.
Best regards
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
