XMG1930 IPv6 Prefix Setup glitch
rfs666
rfs666 Posts: 4 image  Freshman Member
3 VLANs (1,42,228) setup and enabled for IPv6. In "IPv6 Neighbour Discovery Setup" and "IPv6 Router Discovery Setup" they are indexed 1=1, 42=2, 228=3.
Under "IPv6 Prefix Setup" it's indexed differently 1=1, 228=2, 42=3 and if you e.g. click 2 and enter edit mode, it shows VLAN42 in the interface drop down.
If you click index 3 (which is shown as 42) and the edit dialog appears, it shows VLAN228 as selected.
I wonder if this also does break Inter-VLAN routing on IPv6, as it's not working.
  • Zyxel_Tina
    Zyxel_Tina Posts: 700 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @rfs666,
    We have identified this issue, and the resolution will be included in a future release. Thank you for your patience and understanding.
    Zyxel Tina
