Flex H - Camtive portal
We verified a configuration that the customer requested, which was to define only certain PCs on the LAN that would be restricted via captive portal. We contacted Zyxel support, and they confirmed that, as with the ATP series, it's not possible to specify an IP range excluded from the captive portal feature managed on the same network. Only individual IPs, interfaces, or services can currently be excluded. This limitation is very frustrating and limits the functionality often used on the ATP series.
Could you describe more details with us? The specific LAN has lots of devices, like printer, IP phone, IoT devices, PCs, and you want only PCs need to authenitcation by captive portal?
Zyxel Melen0 -
The next firmware, V1.36, will support selecting an address or address group in the source address for specific interface.
Does this match your requirement?
Zyxel Melen0 -
Hello!
How can I select Incoming "WAN" as source for the captive portal?
Best regards,
MJR
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 511 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
