Zyxel USG700 zabbix monitoring
bolvarHUN
bolvarHUN Posts: 3 image  Freshman Member
Dear All!
I want to monitor my new usg in zabbix, i saw that mib are available for it, but for zabbix i didnt found a proper way to install them, if i try to import then i get an error.
Do you have some trick to do this?
Thank you for your help!
bolvar
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,680 image  Zyxel Employee
    Hi @bolvarHUN
    You may try the steps below:
    Step 1: Verify the Existence of the MIB Directory
    First, let’s check if your MIB directory is created on Linux. To do this, you can use the following command:
    ls /usr/share/snmp/mibs
    Do you see any MIB files? Does your output resemble the one in the image below?
    Listing of MIB Files on Linux OS
    If you have that directory and the MIB files within it, then proceed to the next step. However, if you do not have the directory or the MIB files, you can install them using the following commands below:
    Debian / Ubuntu / Raspberry Pi OS:
    sudo apt install snmp-mibs-downloader
    RHEL / CentOS / Oracle Linux / Alma Linux / Rocky Linux:
    sudo yum install net-snmp
    Step 2: Download MIB Files to the MIB Directory
    Here is the mib file link:
    USG FLEX 700
    If your firewall is other model, please visit the Zyxel download library to download.
    Step 3: Restart the Zabbix server
    systemctl stop zabbix-server
    systemctl status zabbix-server
    systemctl start zabbix-server
    Hope this helps.
    Zyxel Melen
  • bolvarHUN
    Dear Melen!
    Okay download, and how.
    If i download it the windows and copied the ZYXEL-ES-WIRELESS.mib into the folder nothing i see.I have to rename it to mib.txt as the others?
  • Zyxel_Melen
    Hi @bolvarHUN
    You can change rename the file extension to .txt. The content of our MIB file is plain text.
    In addition, our experience is only on a Linux-based Zabbix server. If you need further help, you can check with Zabbix or raise the question on the Zabbix forum.
    Zyxel Melen
  • GIPS98000
    GIPS98000 Posts: 2 image  Freshman Member
    Hi !
    Even after importing your MIBs you'll need a template, and … there is none… you can use some generic network template, but you'll have to fine tune it…. a lot…
    Plus you won't have many metrics in the mibs…
