SSL VPN failed on macOS and Linux OS
Device: Zyxel USG FLEX 500
Firmware Version: (please insert your firmware version here)
Service: SSL VPN
Issue:
SSL VPN is not working on macOS and Linux clients.
The connection works normally on Windows using Zyxel SecuExtender, but macOS and Linux clients fail to establish the SSL VPN tunnel.
Error messages:
- macOS: “Unable to establish SSL connection”
- Linux: tunnel interface is not created or shows “TLS connection failed”
Hi @ANVAR_ANVAR,
Welcome to the Zyxel Community!
Regarding your observation, the USG FLEX 500 does not provide an SSL VPN client for Linux, which is why the SSL VPN tunnel cannot be established on Linux platforms.
For macOS, could you please confirm which VPN client you are using, the built-in macOS VPN or Zyxel SecuExtender?
Additionally, since the connection attempt is failing, could you please help check the device’s Event Log at the time the SSL VPN connection fails? Kindly share the relevant log entries or screenshots so we can further analyze the issue and assist you more effectively. Thank you for your cooperation!
Zyxel Tina
Hi ANVAR_ANVAR,
I just posted a guide on how to configure an Ubuntu for IKEv2. You may consider checking it out.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
