Security Policy Control Log
Danee
Danee Posts: 9 image  Freshman Member
I have an USG FLEX 200H firewall,
and I didnt find a way to make log from Security Policy Control events and save the log.
The log in Log&Reports⇒Log/Events⇒System⇒Security Policy Control is very short in time range: 2-3 minutes long event list.
Is there a way to make it longer and be saved or reported in email?
Also:
Can I log incoming traffic by IP in the firewall?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,677 image  Zyxel Employee
    Hi @Danee
    To log for any security policy, you can change the log setting in each of them.
    Here is the place you set.
    No, you can use USB storage or syslog server to save the logs. You may check our handbook page 220 ~ 224 to learn how to setup.
    The firewall records the traffic with src. IP and dst. IP once you have set the security policy and the traffic match this policy.
    For example, I have a security policy "WAN to ZyWall, deny all"; then I can see the blocked traffic by which src. IP.
    Zyxel Melen
  • Peppino
    Peppino Posts: 186 image  Master Member
    First Comment Friend Collector Eighth Anniversary
    A syslog server? That could do the job if you have a server already.
  • Zyxel_Melen
    Hi @Danee
    Zyxel Melen
