References of Network Interface
Rösti
Observed likely a bug.
If I have an (ethernet or vlan) interface used as Interface filter criteria in Diagnostic - Packet capture and then it is removed from the criteria list, Reference (under Interfaces view) is still shows it under packet capture until reboot.
Hi @Rösti,
Since we first tried to reproduce the issue but were unable to replicate the same behavior on our side, to assist us in investigating further and providing better support, could you please:
- Provide some screenshots or a video recording (e.g., using Jam video) showing the issue you have observed.
- Share the device model name and the firmware version of your USG FLEX H device. (We used V1.36 (ABXF.0) when attempting to reproduce the issue.)
With these details, we can conduct a more thorough investigation to determine if this is a bug and help you find a suitable workaround or fix.
Thank you for your cooperation!
Zyxel Tina
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
