Wirless Bridge between FRITZ!Box 5690 Pro (root) and Zyxel NWA130BE (client)
I try to setup a wirless bridge between a FRITZ!Box 5690 Pro (as root) and Zyxel NWA130BE (as client).
In Nebula i enabled 'Wireless Bridge' witch also enables 'Smart mesh'.
On the FRITZ!Box i couldn' t find any special settings.
On both devices the SSID settings are equal.
What else is missing?
Hi @Tilo
Zyxel NWA130BE can only connect smart mesh with Zyxel access points and USG Lite 60AX, it can't connect smart mesh with FRITZ!Box or other devices. If you want to extend your WiFi converge area, you may consider WiFi roaming.
Below are the FAQs for you to reference:
The Difference Between Roaming and Mesh in Wireless Networks — Zyxel Community
How to enable Wi-Fi roaming for devices transitioning between access points? — Zyxel Community
Zyxel Melen0
Hi @Tilo
Zyxel Melen0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
