Random latency handling delays on FLEX H at low bandwidth
USG FLEX 700H V1.36(ABZI.0)
So I know this to be the case with some testing I have done with BQM by thinkbroadband.com and StarTrinity CST by FLEX 700H vs FLEX 200 (non H)
With any luck this can be fixed by firmware and is not a hardware limitation?
My understanding of FLEX H is the sessions get put on fast path CPU if allowed but I'm seeing ping spikes over 100ms by BQM which ping every second and StarTrinity CST which does a UDP ping.
How I know is my BQM was on FLEX 200 and has been stable for many years then moved it to FLEX 700H and seeing random spike at not much load plus if a run StarTrinity CST in a VirtualBox to route to FLEX 200 when I see these spikes on FLEX 700H it shows fine so there is some random handling delays going on with FLEX H.
Update on issue
This problem looks to be due to my big list of trusted wildcard FQDN of about 500 when I disable this list and allow HTTPS any latency is fine.
So is there anything that can be done?
Hi @PeterUK
May I know the destination of the tests - thinkbroadband.com and StarTrinity CST - are in the list of your trusted wildcard FQDN?
P.S. I will check with our team if this can be improved or not.
Zyxel Melen0 -
Hi Melen
The issue can be as bad as over 500ms or even packet loss.
The StarTrinity CST is speed load test and UDP test which I allow the UDP to destination IP range and thinkbroadband.com is just ICMP inbound to interface but you don't need them to to see the problem just a ping out to a stable source will show the problem and by a browser like Edge if you make a favourite folder like with the following then right click on the folder and click open all the problem really shows.
https://uk.yahoo.com
https://www.grc.com/intro.htm
https://app.zerossl.com
https://www.thunderbird.net/en-US/
https://www.amazon.co.uk
https://twit.tv
https://www.softpedia.com
https://www.abuseipdb.com
https://www.virtualbox.org
https://community.zyxel.com/en/
https://www.twitch.tv
https://app.brevo.com
https://www.microsoft.com/en-us/software-download/windows11
https://www.theregister.com
https://www.zyxel.com/global/en
https://www.home-assistant.io
https://nebula.zyxel.com
https://www.realtek.com
https://www.guru3d.comC:\Windows\System32>ping -w 1000 -t 1.1.1.1
Pinging 1.1.1.1 with 32 bytes of data:
Reply from 1.1.1.1: bytes=32 time=11ms TTL=58
Reply from 1.1.1.1: bytes=32 time=14ms TTL=58
Reply from 1.1.1.1: bytes=32 time=10ms TTL=58
Reply from 1.1.1.1: bytes=32 time=9ms TTL=58
Reply from 1.1.1.1: bytes=32 time=221ms TTL=58
Reply from 1.1.1.1: bytes=32 time=13ms TTL=58
Reply from 1.1.1.1: bytes=32 time=20ms TTL=58
Reply from 1.1.1.1: bytes=32 time=545ms TTL=58
Reply from 1.1.1.1: bytes=32 time=107ms TTL=58
Reply from 1.1.1.1: bytes=32 time=581ms TTL=58
Reply from 1.1.1.1: bytes=32 time=68ms TTL=58
Reply from 1.1.1.1: bytes=32 time=72ms TTL=58
Reply from 1.1.1.1: bytes=32 time=463ms TTL=58
Reply from 1.1.1.1: bytes=32 time=335ms TTL=58
Reply from 1.1.1.1: bytes=32 time=578ms TTL=58
Reply from 1.1.1.1: bytes=32 time=728ms TTL=58
Reply from 1.1.1.1: bytes=32 time=127ms TTL=58
Reply from 1.1.1.1: bytes=32 time=19ms TTL=58
Reply from 1.1.1.1: bytes=32 time=18ms TTL=58
Reply from 1.1.1.1: bytes=32 time=162ms TTL=58
Reply from 1.1.1.1: bytes=32 time=28ms TTL=58
Reply from 1.1.1.1: bytes=32 time=11ms TTL=58Ping statistics for 1.1.1.1:
Packets: Sent = 27, Received = 27, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 9ms, Maximum = 728ms, Average = 155ms0 -
But here is the full list of wildcard FQDN where I have three groups to allow them for HTTP and HTTPS then a block rule for HTTP and HTTPS.
Hi @PeterUK
Could you help to provide:
- The issue configuration.
- The interface and testing device's IP address.
We will apply your configuration to replicate this issue. Thanks.
Zyxel Melen0 -
The issue impact all interfaces when when it happens on the given interface.
I will PM the config
Hi
Just seeing if you was able to see the issue?
Hi @PeterUK
Yes, our team replicate this issue, and we are under investigation. I will keep you posted once I get further information.
Zyxel Melen2 -
Hi @PeterUK
We upgraded one of our clients' devices from an ATP500 to a Flex700H. We even reconfigured the device from scratch. The client has a list of many allowed and blocked websites, almost all of which have reached their limits. However, one of the biggest problems is that the web interface is incredibly slow. For example, when you make a change and click save, you have to wait 1-2 minutes. Do you experience similar slowdowns?
For me the web interface seems fine but I read others have the same problem and might be linked too Device Insight being enabled? in system > advanced which I have disabled
Hi @PeterUK
After our replication and investigation, your issue is an inefficiency issue caused by the security policy priority.
To improve it, please add/move the security policy "DNS from DMZ to WAN1; service DNS; allow".
Zyxel Melen0
- 588 USG FLEX H Series
- 477 News and Release
