Impossible to update firmware ZyWALL 310
Hi dear,
i've a small problem, i'm trying to update the firmware of my Zywall 310 (i have two with HA PRO) but i can't, i get an error like :
I have two network cables (one on each VPN) but only one is light on (network up), the second is light down. Both cables have network ...
Thanks for your help
errno: -42012 errmsg: Device HA Pro is activated but the passive device is offline. The firmware upgrading process has been terminated. |
Hi @steve15f
To upgrading firmware when Device-HA Pro is enabled.
System will upload firmware to passive device(ZyWALL#2) first.
After passive device(ZyWALL#2) upgraded completely, then active device(ZyWALL#1) start to upgrading firmware.
ZyWALL#2 will take over all of traffic and role will be “active” until next failover.
Device-HA Pro is detected your passive device is offline so it stop upgrading process.
Please make sure passive device is sync-able with active device and status shows “success”.
Thanks a lot it's working0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
