Impossible to update firmware ZyWALL 310
steve15f
steve15f Posts: 16 image  Freshman Member
edited April 2021 in Security
Hi dear,
i've a small problem, i'm trying to update the firmware of my Zywall 310 (i have two with HA PRO) but i can't, i get an error like :
errno: -42012
errmsg: Device HA Pro is activated but the passive device is offline. The firmware upgrading process has been terminated.
I have two network cables (one on each VPN) but only one is light on (network up), the second is light down. Both cables have network ...
Thanks for your help
  • Zyxel_Stanley
    Hi @steve15f
    To upgrading firmware when Device-HA Pro is enabled.
    System will upload firmware to passive device(ZyWALL#2) first.
    After passive device(ZyWALL#2) upgraded completely, then active device(ZyWALL#1) start to upgrading firmware.
    ZyWALL#2 will take over all of traffic and role will be “active” until next failover.
    Device-HA Pro is detected your passive device is offline so it stop upgrading process.
    Please make sure passive device is sync-able with active device and status shows “success”.
  • steve15f
    Thanks a lot it's working
  • Zyxel_Stanley
    Hi @steve15f
    It's good to know you resolved it. :+1:
