SBG5500-A ISP with two IP Ranges x.x.x.x/30 and y.y.y.y/29 any ideas on how to configure?
Wasteaccountant
The ISP's concept is that the /30 is the connection, but verification of user is done using the /29 ip range.
Through this was going to be a simple case of setting up the WAN as the /30 and setting up the LAN as the /29 address - but the /29 address is not permitted in the LAN
I can configure the subnet to /29, as the below image shows.
Maybe I misunderstand what you mean. Would it be possible to provide the real IP address(es) you'd like to configure so that I can test it from my side?
Thank you.0
- 595 USG FLEX H Series
- 480 News and Release
