FLEX 200H - loss of 2.5GB
DanofWoodstock
DanofWoodstock Posts: 8 image  Freshman Member
I converted from a FLEX 500 to the FLEX 200H to gain the 2.5Gb network speed needed. I've had many issues with the 200H talking to the XMG1915 which drives the WBE530 APs. Nothing I've found allows for VPNs across this network - only LAN1 works.
Additionally, the FLEX 200H lost the 2.5Gh option on all LAN ports (3-8) post Update to v1.36(ABWV.0). Tried to revert to the older version and got the same
Has anyone seen this and know how to get the 2.5Gb back?
u200h-3 112925.PNG u200u 1GB vs 2.5Gb - All UTM off.PNG u200u 1GB vs 2.5Gb - V1.35&v1.36 fail.PNG u200u Dashboard 1GB vs 2.5Gb - All UTM off.PNG
    PeterUK Posts: 4,446 image  Guru Member
    as listed here
    USG FLEX 200H | USG FLEX Firewall - License & Spec | Zyxel Networks
    Only port 1 & 2 are 2.5Gb the others are 1Gb
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @DanofWoodstock
    Which VPN can't access which network? Could you share some details about your setting?
    Additionally, the FLEX 200H lost the 2.5Gh option on all LAN ports (3-8) post Update to v1.36(ABWV.0). Tried to revert to the older version and got the same Has anyone seen this and know how to get the 2.5Gb back?
    USG FLEX 200H only provides port 1 & 2 that supports 2.5G. The other ports only support up to 1G. You can check our website for the device specific details.
    Zyxel Melen
