Can't change EN password GS2220-28HP [FW V5.00(ABRR.2)]
cynik606
cynik606 Posts: 5 image  Freshman Member
edited December 2025 in Switch
I'm trying to use SSH cli on my switch.
GS2220-28HP# enable
Password: 1234
Warning: The enable password is default. Please change the enable password first.
GS2220-28HP# enable password 12345
enable *password
% Invalid input detected at '*' marker.
GS2220-28HP# password
%Invalid command "password"
Best Answers
  • Zyxel_Tina
    Zyxel_Tina Posts: 701 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @cynik606,
    Regarding the issue you’re experiencing, let me clarify this for you. Please note that you need to enter config mode to set up the password if you receive the message, “Warning: The enable password is default. Please change the enable password first.” For example:
    GS2220# enable
    Password: 1234
    GS2220# config
    GS2220(config)# password 12345
    Enable password level 14 set.
    GS2220(config)# exit
    Zyxel Tina
  • Zyxel_Tina
    Hi @cynik606,
    Additionally, we have implemented an enhanced security feature for password configuration. If you prefer to keep your password hidden while setting it, we recommend using the following commands to ensure it is not visible to others during the process.
    GS2220# config
    GS2220(config)# password privilege 14 password
    New password:
    Retype password:
    Zyxel Tina
  • Zyxel_Tina
    Hi @cynik606,
    GS2220# enable
    Password: 1234
    GS2220# config
    Zyxel Tina
  • Zyxel_Tina
    Hi @cynik606,
    GS2220# config
    New password:
    Retype password:
    Zyxel Tina
