NWA50AX Pro - Random Reboots & "Internal hardware watchdog timeout" under load
rosariodellib
rosariodellib Posts: 4 image  Freshman Member
I am opening this thread to report a critical instability issue affecting two NWA50AX Pro units.Both devices experience random spontaneous reboots. The system log consistently reports the following error:Device is rebooted by internal hardware watchdog timeout!
Environment:
  • Devices: 2x NWA50AX Pro.
  • Management: Currently in Standalone Mode (I factory reset them and moved away from Nebula to rule out cloud config issues).
  • Power Source: Zyxel GS1005HP PoE+ Switch (Brand new, replaced specifically to rule out power issues).
  • Network Load: The Wi-Fi network handles constant video streaming from 8 IP Cameras.
Troubleshooting steps already performed (Issue persists):To isolate the root cause, I have already tried the following conservative configurations, but the Watchdog still triggers a reboot:
  1. Hardware: Replaced the PoE Switch and all Ethernet cables.
  2. Radio Configuration: Reduced 5GHz Channel Width from 160MHz to 80MHz (and even 40MHz) to reduce CPU load.
  3. CPU Offloading: Switched from "Multicast to Unicast" to Fixed Multicast Rate (configured at 11Mbps for 2.4G and 24Mbps for 5G) to relieve the CPU from packet conversion tasks.
  4. Features Disabled: Smart Mesh is OFF, DCS is OFF, 802.11r is OFF.
Conclusion:Since the issue happens on two different units and persists even after replacing the power source and minimizing CPU load via configuration, this appears to be a Firmware/Driver instability (likely a memory leak or driver freeze handling constant UDP/Multicast streams).
Request for Support:
  1. Is there a specific stable or Beta Firmware available that addresses this Watchdog Timeout / CPU Freeze issue?
  2. I have the diag-info files ready from the Standalone GUI. Should I upload them here, or do you require me to onboard the APs back to Nebula Cloud for remote inspection?
Looking forward to a solution as the network is currently unstable.
Thanks.
  • Zyxel_Tina
    Zyxel_Tina Posts: 646 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    edited December 2025
    Hi @rosariodellib,
    Welcome to the Zyxel Community!
    It appears that you have also opened a ticket. We have received the ticket and are already working on it. We will keep you updated with any further information via the ticket when it's available.
    Thank you for your patience.
    Zyxel Tina
