FlexH 1.36 uOS - System Advanced parameters missing on Nebula
GiuseppeR
GiuseppeR Posts: 581 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
I cannot find these Additional features on Nebula:
Have I to enable them only via local UI?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,367 image  Zyxel Employee
    Hi @GiuseppeR
    Certainly, the "System Advanced parameters" option is not accessible within Nebula. This is because Nebula offers a foundational configuration with streamlined management. For expert users, it is recommended to configure the firewall through the device's local GUI. You may use the remote configurator to access.
    Zyxel Melen
    PeterUK Posts: 4,342 image  Guru Member
    edited December 2025
    Yes features like these and more are missing I think they just want a clean look on Nebula which I don't like.
  • GiuseppeR
    Exactly, we need to replicate the same UI otherwise the config is splitted and you have to remember where you can find that specific setting you are looking for
    With the way it is for FLEX H you should be able to go from Nebula to local UI to and from without problem which problems could happen when doing this but if they as mindful of the config settings that are missing to not undo what you want it shouldn't be a problem.
  • GiuseppeR
    You can go from Nebula to local UI, only via Remote Configurator, but I see a lot of missing parameters on Nebula like this one:
  • Zyxel_Melen
    Hi @GiuseppeR
    Zyxel Melen
