SFP module doesn't support DDMI - Zyxel RGS200-12P
By default DDMI is disabled
So enable it:
CLI:
Enable DDMI:
#configure terminal
(config)#ddmi
(config)#ex
sh interface GigabitEthernet 1/9 transceiverGigabitEthernet 1/9
Transceiver InformationVendor : AVAGO
Part Number : ABCU-5740RZ-HP8
Serial Number : CN64G2C152
Revision :
Date Code : 2016-04-14
Transceiver : 1000BASE_T
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
Tx: transmit, Rx: receive, mA: milliamperes, dBm: decibel-milliwatts.
% SFP module doesn't support DDMI
sh interface GigabitEthernet 1/11 transceiverGigabitEthernet 1/11
Part Number : AFBR-5710PZ
Serial Number : AM151326680
Revision :
Date Code : 2015-03-31
Transceiver : 1000BASE_SX
Any idea why?
Hi @scerazy
Copper transceiver normally not support ddmi info. But the fiber transceiver doesn't support DDMI could be because the vendor doesn't provide the ddmi info to the switch.
In addition, ZYXEL switch products are recommended to be used exclusively with ZYXEL brand modules to ensure optimal performance and reliability. Using modules from third-party sources can potentially lead to decreased network performance and reliability, such as packet loss and connectivity issues, which also cannot be guaranteed by ZYXEL. ZYXEL may not offer technical support for networking issues that are identified as being caused by IOP with third-party modules.
Here is the result when using Zyxel fiber transceiver:
show interface GigabitEthernet 1/9 transceiver
GigabitEthernet 1/9
Transceiver InformationVendor : ZYXEL
DDMI Information
Part Number : SFP-LX-10-E
Serial Number : S243Q27401301
Revision : J1.0
Date Code : 2024-07-03
Transceiver : 1000BASE_LX
Tx: transmit, Rx: receive, mA: milliamperes, dBm: decibel-milliwatts.current High Alarm High Warn Low Warn Low Alarm
Threshold Threshold Threshold ThresholdTemperature(C) 30.965 95.000 85.000 -40.000 -50.000
Voltage(V) 3.2783 3.5000 3.4500 3.1500 3.0900
Tx Bias(mA) 18.312 90.000 80.000 2.000 1.000
Tx Power(dBm) -5.20 -2.00 -3.00 -9.00 -10.00
Rx Power(dBm) -40.00 -- -2.00 -3.00 -20.00 -21.02Zyxel Melen0 -
Seems like AVAGO AFBR-5710PZ doesn't support DDMI.
Zyxel Melen0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
