Where is the ZON Utility?
asincero
asincero Posts: 4 image  Freshman Member
Where's the link to the ZON utility. When I go to the URL in the Quick Start Guide, it takes me to a page where I select the product. When I select my product, it then takes me to a page with a bunch of file links, none of which is a link to the ZON utility.
  • Zyxel_Tina
    Zyxel_Tina Posts: 723 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @asincero,
    Welcome to the Zyxel Community!
    To download the ZON Utility, you will need to scroll down the page, fill out your contact information, and submit it. Once your submission is successfully processed, Zyxel will send the download link directly to your email with the subject line "Your Requested ZON Utility."
    Please also check your spam or junk mail folder in case the email is filtered there.
    Zyxel Tina
  • XiLeiHaLo
    XiLeiHaLo Posts: 17 image  Freshman Member
    First Comment First Answer Friend Collector Fourth Anniversary
    Don't click the product when you go to the URL. Just fill all the information in "Your Contact Info" at the bottom then you will receive the ZON Utility.
  • Zyxel_Tina
    Hi @asincero,
    Zyxel Tina
