FlexH 1.36 uOS - System Advanced parameters missing on Nebula
Hello everyone,
I cannot find these Additional features on Nebula:
Have I to enable them only via local UI?
Hi @GiuseppeR
Certainly, the "System Advanced parameters" option is not accessible within Nebula. This is because Nebula offers a foundational configuration with streamlined management. For expert users, it is recommended to configure the firewall through the device's local GUI. You may use the remote configurator to access.
Zyxel Melen0
Yes features like these and more are missing I think they just want a clean look on Nebula which I don't like.
Exactly, we need to replicate the same UI otherwise the config is splitted and you have to remember where you can find that specific setting you are looking for
With the way it is for FLEX H you should be able to go from Nebula to local UI to and from without problem which problems could happen when doing this but if they as mindful of the config settings that are missing to not undo what you want it shouldn't be a problem.
You can go from Nebula to local UI, only via Remote Configurator, but I see a lot of missing parameters on Nebula like this one:
Hi @GiuseppeR
Zyxel Melen0
- 591 USG FLEX H Series
- 478 News and Release
