Fallback to lastgood configuration
I have a problem with a ZyXEL FLEX 200 that has been moved to a new physical location. Everytime it reboots, the boot status goes back to "Fallback to lastgood configuration"
I seem to have solved it now by removing an old L2TP_VPN Connection which isn't in use anymore.
It mentioned something about can't crypto… for that VPN in the logfile. But how is that possible that it gets into the config file if it is not able to work?
There was 1 L2TP VPN connection and I added an extra IKEv2 Gateway with 2 VPN tunnels on that gateway. 2 Tunnels because 2 VLAN's that had to be connected with 1 on other site.
I still have the "corrupted" configfile if I have to look something up on it.
Firmware = V5.41(ABUI.0)
Also in old site I had a PPPoE account with filled in username, it gave an error also on that in logfile(but I don't need it filled in anymore). I filled now fake user in, but can't remove it? Ok Button grays out
Update
The issue is because the L2TP config has a non-existent address object, which can't be replicated in the latest firmware version.
Zyxel Melen0
I will send you a private to get the config file.
About the pppoe account, this seems like is a default account. The default account is not able to removed. I suggest loading a config file that remove the username & password of this ISP account object.
account pppoe WAN_PPPoE_ACCOUNT
!Zyxel Melen0 -
Update
Zyxel Melen0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
